jndsoccer
  1. I finally got it working. The problem ended up being that when I copied the example for the resource, I was using the MS Edge browser and it ended up putting some weird characters (0xC2 0xA0) for each leading space on each line . When I just retyped it, or used Chrome to copy it so the spaces were 0x20, everything was fine. I also was able to use "Raw Text" rather than "C-Escaped" to keep the code in the Body window in a sane format.
  2. Blueman2 - Yes, it's the popup when I try to test it. Here is my Network Resource definition. One other weird thing, when I click on "more Info" in the Portal tab, I never get the page to load.
  3. Blueman2 - Thanks for the step by step instructions. I followed everything and double checked my cut-and-pastes but I keep getting "Error: TCP client request failed [Net Module Rule 1:400]". It appears I still don't have something connected quite right. I'm very new to the net resources stuff. Any place that is well documented for beginners that you can recommend for me to start debugging? It seems most of the Wiki and Forums are great references for those who know what is going on, but few (other than your great step by step with examples) for us newbies. ISY 994i v4.5.4 w/Portal Integration Thanks again
