juniorx
  1. I think I became off, because my "new PLM" did not function. I now reverted to an old-old back up and the scenes now work. I am only out my recent updates. Thank you all for the help.
  2. FYI, as per http://forum.universal-devices.com/topic/20275-replaced-plm-now-having-communication-issues/, I did right click on the modules with issues and then click on restore device.
  3. I use an ISY-994i/IR-PRO and 2431S Powerlinc modules for my devices. PLM died and I bought a replacement. The first replacement was faulty and the seller provided a new one that *mostly* works. I followed the Restore Modem and Restore Devices link, as suggested in other posts. Everything appeared to recover correctly (no "1011" green tags on devices). The primary issue I have is that "scenes" do not control the lights correctly. My 8 button switches have buttons tied to a scene (example is "Outside lights") and the button still controls all outside lights. However, the ISY can not control all of the lights in the scene. I can "querry" and "turn on" lights, but the individual lights do no responde. Running a tools->diagnostic->scene tests responds with: Sun 01/22/2017 19:39:45 : [GRP-RX ] 02 61 15 13 00 15 <html><font color="red">----- OutsideLights Test Results -----</font></html> <html><font color="red">[Failed]</font> LT_ExtFrontDoor (23 FC 5B 1)</html> <html><font color="red">[Failed]</font> LT_InsideGarage (24 4 37 1)</html> <html><font color="red">[Failed]</font> LT_ExtGarage (24 5 54 1)</html> <html><font color="red">[Failed]</font> SW8_BR_MB - H (24 FD CE </html> <html><font color="red">[Failed]</font> SW8_KitKneeWall - H (25 0 F1 </html> <html><font color="red">----- OutsideLights Test Results -----</font></html> Sun 01/22/2017 19:39:54 : [INST-TX-I1 ] 02 62 14 E0 C0 0F 0D 00 Sun 01/22/2017 19:39:54 : [INST-ACK ] 02 62 14.E0.C0 0F 0D 00 06 (00) Sun 01/22/2017 19:40:03 : [INST-TX-I1 ] 02 62 14 E0 C0 0F 0D 00 Sun 01/22/2017 19:40:03 : [INST-ACK ] 02 62 14.E0.C0 0F 0D 00 06 (00) Sun 01/22/2017 19:40:07 : [INST-TX-I1 ] 02 62 21 C7 80 0F 0D 00 Sun 01/22/2017 19:40:07 : [INST-ACK ] 02 62 21.C7.80 0F 0D 00 06 (00) Sun 01/22/2017 19:40:16 : [INST-TX-I1 ] 02 62 21 C7 80 0F 0D 00 Sun 01/22/2017 19:40:16 : [INST-ACK ] 02 62 21.C7.80 0F 0D 00 06 (00) Sun 01/22/2017 19:40:25 : [INST-TX-I1 ] 02 62 21 C7 80 0F 0D 00 Sun 01/22/2017 19:40:25 : [INST-ACK ] 02 62 21.C7.80 0F 0D 00 06 (00) From the ISY admin interface, I can turn on "Outside lights", but switches do not respond, even though ISY shows lights as "ON". I have tried moving my PLM and ISY to different outlets around the house with the same results. All of the scenes and devices worked for ~3 years prior to the first PLM dieing. Any debug suggestions?
  4. You rock. It appears I have three separate issues: 1. PLM failed. (Procured new one and must follow the directions.) 2. Ethernet cable I was using at my PC was bad. (This is why I was getting Memory and Error to blink together.) You got me past this one:) 3. Missing programming files? Thank you. The blink codes are helpful and I did not find that before.
  5. After posting this, I see http://forum.universal-devices.com/topic/19733-cannot-retrieve-programs-could-no-open-config-file-to-read/ . The "Memory" and "Error" lights blinking came back after I attached the new PLM to the ISY.
  6. I am in need of some help, before I go out and buy another isy994. Posts Related to my experience: http://forum.universal-devices.com/topic/6697-isy-99i-red-light-and-error-message/ http://forum.universal-devices.com/topic/14315-isy994i-flashing-red-error-bad-sd-or-other/ ISSUE: "Memory" and "Error" lights blink after ISY-994i/IR-PRO boots. BACKGROUND: Use an ISY-994i/IR-PRO and 2431S Powerlinc modules for my devices (approximately 3 years old). a. After a power outage, I could not longer communicate with my ISY-994 via MobiLinc app or URL via home PC. Noticed that the 2431 green LED was not lit. Unplugged PowerLinc and could communicate with my ISY, although all programs were missing. b. Bought a new PowerLinc module and rebooted system to get "Memory" and "Error" lights blinking. From manual, read that it was a bad micro sd card. c. Bought "Kingston Digital 16 GB Class 4 microSDHC Flash Card" via amazon.com. Plugged in new SDcard and no bad lights (yippie). I could not use the admin console, with same issues as http://forum.universal-devices.com/topic/14315-isy994i-flashing-red-error-bad-sd-or-other/ . Formated the sdcard via telnet. (No PowerLinc attached.) d. Still could not access the admin console. I could access my old sdcard from my PC. Copied contents onto new SDcard. Put new SDcard into ISY. Rebooted and could access via admin console. Restored a good copy of my ISY configuration. (Still did not have any programs.) Updated ISY firmware to 4.5.4 via admin console. (No PowerLinc attached.) e. Repowered ISY and logged in via admin console, things looked good. (No PowerLinc attached and no progams.) f. Moved ISY to a new location in the house and repowered with PowerLinc attached. Get "Memory" and "Error" lights blinking. Tried reformatting sdcard on PC, using old sdcard, and resetting ISY to factor settings. Nothing appears to work. QUESTION: - Is my ISY hosed and needs to be replaced? - Do the modules only work for ~3 years? If so, this is a lot of money to shell out ever few years. What are better alternatives?
