JFrary01
Everything posted by JFrary01
  1. Got this to include in my Zwave network, but it doesn't want to let me convert to Fahrenheit for temp display and is very unstable in sensing and reporting any and all parameters. Help?
  2. Just to close the loop on this: I did all as Geddy suggested, however I then needed to open a ticket and Benoit discovered that the nodes added by each nodeserver added them with default "type" of 0.0.0.0. Benoit had me change the type to 2.0.0.0 using the "hint editor" in the portal under connectivity. I was then able to add "spokens" for each device and then Alexa was able to discover them. Thanks, all.
  3. Thanks. Sounds like that should work, but: I disable the Alexa skills for both Wemo and Kasa applications, but same results. Then I wait about 24 hours, reboot, restart everything, same results. Then I uninstall and delete both nodeservers from Polisy, delete all Wemo and Kasa devices from ISY, reboot and restart everything, same results. I ask Alexa to discover devices; she finds one Wemo device, but I still can't add a spoken for that device. I still must be missing a step, or there is some other issue. So, I'll open a ticket.
  4. Just occurred to me that since the KASA and Wemo apps have provision for names, and are linked to Alexa, the nodes can be controlled using the names set in the apps., obviating the need for ISY spokens. Still would nice to be able to manage all spokens through ISY. Shall I still open a ticket?
  5. I always get this message when I try to add a KASA or WEMO node server node to the Amazon Alexa connectivity. I've tried switching device types to "light", "switch", "outlet", etc. but always get the same error. Anybody know how to fix this? nodeservers are on Polisy ISY is 5.0.16
  6. not able to add z wave Dome water shut off after upgrade from 5.0.13D to 5.0.16B. Any ideas?
  7. Thanks. I've submitted a support ticket.
  8. I've rebooted multiple times, powered off and on, powered PLM off and on, etc. Lots of error log entries look like this: Sun 2019/09/22 03:21:02 PM System -10108 Check log
  9. checked that. get same behavior on 3 different machines with 3 different OSs
  10. if you mean "save changes" in that panel, then no
  11. Yes. 5.0.10
  12. After months of apparent normal operations, upon opening my admin console, everything appears normal, except all my programs are "gone". Devices are there and can be controlled, variables are there. Any ideas?
