Edmund Lam
Everything posted by Edmund Lam
  1. I did clear the cache and still no go. I manually added : https://.....:8443/desc and got in.
  2. This was working yesterday. I can SSH into the unit. EISY has been up 24 days. Any reason why this happened? Should I just do a reboot from login ?
  3. Thanks. That fixed it. Clear the cache and download a new start.jlnp
  4. I just did the EISY firmware update to 5.8.4. Now I can't login via MY ISY "start.jnlp". Use the current one, it reported that it was 5.8.3 and would need 5.8.4.
  5. I added a 250G m.2 and rand the scripts. It looks like ZUDI is still mirror and we are still using the eMMC. I guess I have to manually remove the eMMC partition mmcsd0p3 from the pool. [admin@eisy /dev]$ zpool status pool: zudi state: ONLINE scan: resilvered 3.43G in 00:00:33 with 0 errors on Tue Feb 27 16:38:12 2024 config: NAME STATE READ WRITE CKSUM zudi ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 mmcsd0p3 ONLINE 0 0 0 nvd0p2 ONLINE 0 0 0 errors: No known data errors [admin@eisy /zudi]$ zfs list zudi NAME USED AVAIL REFER MOUNTPOINT zudi 3.27G 45.7G 24K /zudi [admin@eisy /zudi]$ gpart show => 40 120831920 mmcsd0 GPT (58G) 40 132096 - free - (65M) 132136 106020864 3 freebsd-zfs (51G) 106153000 14678960 - free - (7.0G) => 40 488397088 nvd0 GPT (233G) 40 131072 1 efi (64M) 131112 461373440 2 freebsd-zfs (220G) 461504552 8388608 3 freebsd-swap (4.0G) 469893160 18503968 - free - (8.8G)
  6. I want EISY to see my IOT vlan (wifi) and also be on my main lan (wired).
  7. I stuck a TPLink TL-WN821N USB to Wifi adapter on the EISY. It sees it as wlan0. Why can't we see the onboard Wifi wlan0 ? EISY has both RJ45 and Wifi.
  8. Is anyone working on a node for EspHome devices? No hub needed, the devices have IP and reachable by Wifi over TCP/IP. The ESP8266 and ESP32 are Arduino on steroids with Wifi and BLE. This is for DIY devices, sensors, etc... https://esphome.io/index.html
  9. Is there a way to delete all the links which are not managed and mapped by EISY? Having moved to EISY and a working device/scene map. Is there a way to purge all the old links which were programmed into my 60+ devices and only have the ones managed by EISY. Some of the devices have ancient "hard link" from 2008 when they were manually bonded/linked.
  10. 2486S/WH6 Keypad v.36 Is this broken or does the device not support changing the backlight setting on the buttons. I set the on and off to 2/2. Even 15/7, no change. Update appears to be done, but no change in illumination.
  11. If I enable the Wifi by unhooking the RJ45, will both interfaces be seen by the kernel on subsequent boot? ifconfig should see 3 lans, lo0 (local), re0 (RJ45) and whatever the Wifi.
  12. I ssh-ed in the kernel only reports re0 (LAN). No wifi devices reported by dmesg. I want EISY to access my Wifi IOT LAN which is on its own subnet.
