cfoliaco
Everything posted by cfoliaco
  1. Yes, it is back again. The thing here is: how long…
  2. Sorry, I was assuming that there was a KP and an on/off Switch in the room. In the same way, I think programming you could handle the desired action in some way. Maybe counter variable increasing every double tap... I have done with a on/off switch to change the speed of fanlinc or turn on another light. This on/off switch have no load because is for a two way switch... Hope to be clear jeje
  3. That double tap should to be very closed taps to each other. I guess. But thinking carefully the first option is closer to the goal.
  4. Hi friend, that's why an option is to quit the load from the switch and handle with keypad in room. If that is possible all is about the program.
  5. An option could be make that the double tap increase a counter (Variable), making possible to break in an option according the number in the counter. But as someone has said, can´t avoid turn on or off. For this maybe you could: 1. Use the switch without load. (Understanding that each room have keypad + switch) 2. Do something like: Execute the opposite action in the same program. Explain: If need to turn off music with double tap off and still have lights on, after double tap off turn the light on by the program. Guess the ramp should be relative high. Remember set variable to zero at the end.
  6. Hi, first make a troubleshoot, trying to setup the program part by part. Add a line and try. Maybe you can try configuring a scene with MS and switches, then MS set to On Only and Night only modes, then program a short timer for the day and 5mins timer after 11:00pm. Enviado desde mi iPhone utilizando Tapatalk
