erikeps
  1. @stu - Thank you, this did the trick! works perfectly for Alexa Echo / Dot and Homekit via Raspberry Pi Homebridge! Thank you all for your help! -Erik
  2. @paul - Interesting, i wonder what i am doing wrong. i do have the individual switches and the scenes.. ill do some testing with removing the individual switches, @Gary - so if i am understanding correctly, would this mean i would need to create scenes for 60, 65, 70% etc etc for each 3 way? Thanks for the super quick replies!
  3. Hello, I am hoping someone with more experience can point me in the right direction. I have an ISY 994i ZW/pro, echo and many insteon devices. I have several lights set up in a 3 way configuration. I can use Alexa successfully to control single lights but when they are in 3 way i am running into an issue where i want to set a scene to a certain %. it seems scenes cant be set to other than on and off. it somewhat works if i call a single device in the 3 way. it will set that device to any % setting i want but then the other switch is no longer in sync. does anyone have tips on best way to control 3 ways so that i can say turn on to 65% or dim kitchen from ISY / Alexa thanks!
