daved
  1. Had the same problem - ISY finder not found. Solution was to disconnect VPN on computer.
  2. Does anyone know if there is an Insteon or Zwave temperature sensor compatible with the ISY 994i (with zwave module). I am looking for something that has a temp range high enough to use in an attic. I found a FortrezZ unit model WWA02AA - doe anyone know if this is compatible?
  3. Thanks for the info, but changing the temp on the wireless thermostat does nothing to make it show on the thermostat main screen. It doesn't look like there is even a place on that screen to show the external temp. Only current state and that doesn't show anything.
  4. I just purchased an Insteon wireless thermostat 2441ZTH and want it to control devices based on the external temperature. I have the thermostat set to display the external temperature using the probe and it is linked to the ISY 994, but the current state or the external temperature do not show. Any help will be appreciated. Thanks
