Boomer50BMG
  1. Hi Michel, Unplugged PLM And ISY, waited 10 seconds plugged it in and all is now well. Thanks Randy
  2. Hi Michel, I am using https://isy.universal-devices.com/start.jnlp and utilizing the Admin Console. Last night, I tried to add an Insteon device after rebooting and it went into an infinite Linking loop. I had to unplug the Insteon PLM and plug it back in and reboot the ISY. Now, we are back to the System Busy.. Randy
  3. I am getting Constant System Busy messages since upgrading to 5.0.16C (RC1). My ZWave FW was already up to date. I have looked in the error logs and they are pretty clean. Occasionally, I can reboot enough times and it will stop. However, if I make about any change, it all starts over again. Here is my error.log in case someone can see what I cannot. Time User Code Message Thu 2020/02/27 09:54:59 PM System -5 Start Thu 2020/02/27 09:55:00 PM System -110022 /CONF/INSTENG.OPT Thu 2020/02/27 09:55:00 PM System -110012 /CONF/INSTENG.OPT Thu 2020/02/27 09:55:04 PM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Thu 2020/02/27 09:55:05 PM System -110022 /CONF/UXT.BIN Thu 2020/02/27 09:55:05 PM System -110012 /CONF/UXT.BIN Thu 2020/02/27 09:55:07 PM System -170001 [Network] Established Thu 2020/02/27 09:55:07 PM System -140000 my.isy.io Thu 2020/02/27 09:55:07 PM System -60006 n/a Attached, I have also enclosed the Event Viewer and event logs. Please help. I upgraded only to use the Polyglot stuff (still need to learn it though) The only ZWave stuff controlled by the ISY994iZ IR Pro is a Schlage BE468CAM716 door lock. I have a whole house full of Insteon devices. I did use the Insteon Firmware. I do also have a Samsung Smartthings hub with Zwave and Zigbee devices that are not used with the ISY. Randy ISY-Events-Log.v5.0.16C__Thu 2020.02.27 09.59.19 PM.txt ISY Log.v5.0.16C__Thu 2020.02.27 09.59.57 PM.txt
