CStockard
Everything posted by CStockard
  1. good catch, unfortunately that was just a typo when I wrote the post. The values I have actually entered are 10.0.0.55 and the variations. sorry for the confusion. Issue remains.
  2. I am trying to connect my Meteobridge (sensor data coming from Acurite 5-in-1 / IRIS) to the Meteobridge NS. I am running Polyglot 3.3.18 on an EISY; IoX version 5.9.1 The Node Server is running and shows the appropriate data fields in the UD Admin Console, but I am not getting any data. The Meteobridge is located at 10.0.55. I suspect that I am entering the IPAddress field incorrectly. I have tried entering 10.0.55 and http://10.0.55 and http://10.0.55/, however I still get no data. The Units field is set to "us", Password field has the meteobridge password I use to access is at the 10.0.55 address. Any suggestions? Chris
  3. I have been using Meteobridge to send data to my ISPY on Polisy for quite some time. Unfortunately the Meteobridge Node Server stopped working and disappeared from the Node Server Store. I've paid for and installed WeatherPoly as an alternative. I have read the instructions on the Node and the GitHub configuration information but just can't seem to get a connection between the Meteobridge and WeatherPoly on Polisy. The config info calls for entering the port info into WeatherPoly, but there is no preconfigured field for this info, only long and short poll fields. Unless this represents a problem, then it appears I have to create a custom configured field "port" for this info. I do understand that I will have to create custom configuration fields for the actual Meteobridge data, but I've not gotten a connection yet, so have not worked on that. I created an entry for Home Weather Station - Weather34 in Meteobridge. My issue is that the configuration strings needed in WeatherPoly and in Meteobridge are not working. In Meteobridge I have entered this string in the API URL field: http://10.0.0.56:8080/. When saved it shows a "no connection" red x and an error message "Error: Home Weather Station: Authorization failed." This is the URL of the Polisy In WeatherPoly I created a "port" field and entered 10.0.0.56. I have also tried it with http://10.0.0.56 where 10.0.0. Thanks
  4. Thanks. Not exactly what I was seeking, but tracking through some of the links you provided got me enough hints to get the node working. For some reason I hadn't been able to find those links even though I was on the same GitHub section. Again thanks.
  5. I'd love to be able to send commands to my Sonos Controller from ISY programs. I think this Node Server probably has that ability. The problem I am having is that I can't find and documentation of the command structure. I suspect form the limited instructions in the Node configuration that I can do this using a TTS phrase and a value. I have no idea what values are allowed, their parameters, or syntax. Can someone direct me to this information??
