dismania
  1. dismania replied to dismania's topic in ISY994
    I only added the scene to the portal. I do not have the Insteon hub anymore, once I graduated to the ISY, I gave it to a co-worker.
  2. dismania replied to dismania's topic in ISY994
    I can turn the scene on/off from the ISY admin console. And I checked to make sure Alexa was using the scene and it is. What else should I check?
  3. dismania replied to dismania's topic in ISY994
    ok, a follow-up. The switches work fine, UNTIL I use Alexa to turn the scene off. Once I do that, they all get out of sync. I have to go to the main switch (the one that is hooked up to load), pull the tab, wait 5 seconds, then push it back in. Once I do that, they work fine again as a 3-way, until I turn them off using Alexa. Any ideas? Dismania
  4. dismania replied to dismania's topic in ISY994
    Thank you so much! The answer was thorough, concise and easily followed. It worked like a charm!
  5. dismania posted a topic in ISY994
    I have installed 3 insteon switches in my hallway and bottom of steps. How do I create a link so they all work as one? I did the link where I pushed the set button on one switch, went to the next, etc. That worked last night, but now that I have added it to the ISY, only 1 switch works now. Any help appreciated.
