english_1969
  1. Okay, Get my ISY updated and verified that rest is working. I'll get the rest a shot from my controller. Thanks, W
  2. Thank Bob! I knew you would have an answer...I've been using your plug-in for cinemar for little while with nice success. The crestron can send strings like this, the only thing I may need a little more guidance on is the authentication. So then I have probably simple question: I've not been playing with the ISY that much, so actually getting it updated to the latest firmware is a little fuzzy. Also, is there a simple check I can run to verify that REST is up and working on the unit? Thanks, Warren
  3. As far as i can tell, I could possibly use REST to do this. My crestron controller can talk to ethernet devices although I'm yet sure about it being able to emulate a browser. To get the rest module on my ISY, I need to buy the $49 network module...correct? I noticed I could do that from the admin module. Thanks, Warren
  4. Hi, I am trying to control lights in my insteon network from a crestron controller. I am curious if the serial port on the ISY-99i can be used in a way that would allow for control of lights 'connected' to the isy? Thanks, Warren
