lazarow
Everything posted by lazarow
  1. Michel, It's truly amazing what you can accomplish, when you read the instructions!. I was attempting to access the admin console though a "favorites" link I had on my web browser. As soon as I downloaded the JAVA App and ran it, every thing became hunky-dory. Thanks. Art
  2. BTW, I was ay 2.7.15 when I upgraded.
  3. Alright. After another reboot of the ISY/PLM along with connecting the PLM on another electrical line, and reinitializing the admin console there is still no joy in Mudville. There is no status on any of my units in the admin console. Again, the problem occurred afyer upgrading to 2.8.16. Suggestions? Art
  4. Oberkc, I've tried unplugging and replugging PLM/ISY. BUt I'll go try again. LeeG, Before the upgrade, I was having no problems. Now I can't control anything. I will also try running an extension cord from another outlet. They ISY/PLM is in my electronics room with all the A/V equipment for the house. Thanks to both of you for the reply. Art
  5. I got all my earlier problems squared away. In addition, I made a succesful change swapping out one KPL for another. I then decided to upgrade the firmware to 2.8.16. I followed all the instructions in the Forum for upgrading the firmware. I believe that the upgrade was succesful. The help:about shows the firmware as 2.8.16. However, I still cannot finr the ISY in "My Network Places" and when I open the administrative console through the UDI website none of the statuses are shown. What can I do to fix this? Thanks. Art
  6. Rand, My ISY is not showing up in "My Netwrok Places" even after the reset. Suggestions? Thanks, Art
  7. Rand. After killing power to the PLM and ISY and restoring it, the ISY was unable to communicate with 2 SWL's. They were on the same circuit as the units I replaced. I pulled the units and found a wire had come loose removing power from the 2 downstream SWLs. I have replaced the wire and all is well (for now). I'll upgrade my software later today. Thanks again, Art
  8. Rand, I'm not sure which version (2.8.8, I think) of the firmware I'm running but it definitely needs to be updated. How can I check for the firmware version? I'll power down and power back up and see what happens. Thanks for the support! Art
  9. Yesterday, I decided to do some changes to my installation. I deleted the units (a Switchlinc and a KPL) through the admin console. I made the changes and then started the linking process. The linking process has been running for the last 23 hours. I gather from what I've read in the forums that the ISY is searching for something that it can't find. I failed to delete a scene that one of the units I changed out was in. Is this what the ISY is looking for? How do I stop the linking and correct my error? Thanks. Art
  10. lazarow replied to lazarow's topic in ISY994
    Last night, the ControLinc was not in My Lighting after several attempts to link to it. In addition, the event viewer would not open up. I shut everything down last night and when I opened the adminsitrative control panel, lo and behold, it was there. Then I tried opening up the event viewer and it opened flawlessly. Maybe I was too impatient waiting for the ISY to locate the ControLinc. I don't know but it is in My Lighting now. Thanks for the suggestions. Art Lazarow
  11. lazarow replied to lazarow's topic in ISY994
    Michel, Probably should have mentioned this. When I click on Tools/Diagnostics/Event Viewer, nothing happens. Art
  12. lazarow posted a topic in ISY994
    I have dusted off my ControLinc and was going to use it with some Lamplincs and Appliacelincs to control the Christmas Decorations. I have been unable to link to the ControLinc using the "Link to ControlLinc" Function from the administrative conrol panel. I even ran an extension cord from another outlet to the PLM and connected the ControLinc to the same extension cord. The ISY never recognizes the ControLinc. Help! Art
  13. WAF impact was too great. I pulled the 8-button KPL and replaced it with a switchlinc. KPL was not essential, WAF was. I'll track down the communications issue with a set-up that does not impact the WAF. Thanks for all who tried to help! Art
  14. Rand, She's not got the laptop anywhere near the bathroom. I did take it off-line yesterday and did not get any bad comms but I had good comms with it on-line. I deleted the last scene and device in the master bath and re-added. So far, I haven't had any problems. I'll keep an eye on it and have told the wife that any time she has problems with the lights to come and get me. I added 5 devices yesterday and some more scenes and they have been solid. I keep hoping that I have the problem solved. Thanks, Art
  15. Rand, You're a killjoy and dad gummit you're absolutely right ! I'm still having problems and to make matters worse they are much more intermittent. Also, they are in the Master Bath so WAF is seriously impacted. I haven't been able to disconnect the wife's computer during an episode of affected communications, yet. I've checked most of the other possible offenders. I'll keep you all posted. Thanks, Art
  16. There is joy in Mudville today. Yesterday , I noticed that the LED was completely out in the SWL Relay controlling the Water Closet exhaust fan. I tried to turn the exhaust fan on and nothing happened. I pulled the SWL out and replaced it with another one that I had. The exhaust fan now worked. I deleted the scene that it was in and had the ISY relink with the new SWL relay. I then recreated the KPL button scene. That scene worked so now I had three functioning KPL buttons. I deleted and recreated another KPL button scene and no joy!. I then deleted the SWL's from the ISY and had the ISY relink with all of them. All the KPL button scenes are now functioning. Thanks all for your help. Art Lazarow
  17. I am currently in find the signal sucker/killer mode with my install. I switched out the KPL for another one and the failure mode is identical - One button on the KPL runs its scene, the other do not (The load button works). Currently I have the ISY and the PLM plugged into the same extension cord. I did this when I killed power to the electronics room where the DSL Modem, the wireless router and the PLM are located. Is there any probl;em with having the PLM and the ISY plugged into the same extension cord? Thanks.
  18. I've been working my first big install with Insteon and my first install with my ISY. I have a problem with an 8-button KPL in the master bath. With the various lights and fans in the master bath their are eight switches. I replaced seven of the switches with Switchlincs (dimmer and relays depending on what they control) and one with an 8-button KPL. Everything was fine until the wife used the water closet at night and complained that the LED's from the two switches in the water closet were right in her eyes and too bright. The switchlincs were old ones from a small installation I had done in our previous house, so the LED's could not be dimmed. I replaced the switchlincs with two newer ones that I had that had dimmable LED's. After I replaced the switchlincs (both relays) and threw the breaker, the KPL emitted a constant tone. I airgapped it and it stopped making the tone. Ever since it has not worked right. I'd get spurious results with button pushes (nothing happening, lights coming on that weren't supposed, etc.) Today, I went in and physically unlinked all switches from the KPL buttons and vice versa. I deleted all scenes with the KPL buttons. I verified that the KPL buttons had no links to them. I did a factory reset on every switchlinc and the KPL. I deleted the KPL from "My Lighting" and then re-added it. When I write scenes for the KPL buttons (button 'X' controls switchlinc 'Y' and vice versa), the KPL buttons do not work. If I manually link the buttons and Switchlinc (tap, tap) they work as they should but the administrative console does not accurately represent the KPL button status. 1. Is there anything that I am doing wrong? 2. Is there anything else that I can do? 3. Does anyone out there have any experience with a KPL emitting a solid tone? I'm going to post the last question over on the Smarthome Forum. Thanks, Art Lazarow
