Venicenerd
Everything posted by Venicenerd
  1. Venicenerd replied to C Martin's topic in ISY994
    I am so curious how all of this will play out. Really hoping that ISY will embrace Matter full heartedly. It could be so great!
  2. Venicenerd replied to C Martin's topic in ISY994
    Correct. But if Polisy will be a proper Matter hub any devices connected it could be exposed via Matter. Same as Philip's Hue bulbs won't support matter but the Philip's hub will be upgraded to matter so that the bulbs will be exposed to matter via the hub.
  3. Venicenerd replied to C Martin's topic in ISY994
    What I would like to know is devices available on the ISY will be able to be used by other Matter Hubs. I'm way more interested bridging my Insteon devices from the ISY to other places than having matter devices show up on my ISY. Will this be possible?
  4. I hope you have been able to solve your issue. **HIJACK WARNING - IGNORE IF YOU'RE STILL HAVING ISSUES** Your setup looks exactly like mine so I was wondering if you have had any issues creating your scenes, containing Insteon devices, in Home Assistant itself? When I place more than 3-4 Insteon devices into a Home Assistant scene not all of the Insteon devices respond. I assume the Insteon Network may get overwhelmed? However, when I create an Insteon Scene on the ISY itself and control the entire scene through a Home Assistant Switch the issue becomes that HA will still show the scene/switch as "on" even if not all devices of that scene are turned on. This will stop my automations inside HA from working correctly since they will not turn the scene on again since they believe it's still on. So if I tell Siri "Set the scene arriving home" it will turn on all of the lights and the HA switch for the scene turns on. But then if I turn off just one of the lights in that scene the HA switch will remain as "on". So now when I tell Siri "Set the scene arriving home" it won't turn that light back on since the entire scene still shows as activated in HA. Wondering how you are dealing with this?
  5. Yep. Disabled and deleted. ?
  6. Hahahaha 100%! I have to say I can't fault them. I didn't even remember I had this set up. This has been driving me NUTS for about 5 days now. Been searching high and low for the solution hahaha. Thankfully @Geddynudged me to check the summary tab...
  7. Hi @GeddyI FIGURED IT OUT! Years ago I had set up a vacation mode light program: It appears the guest switched on that button and I didn't remember I ever set this up... WOW! Thank you so much for your help!
  8. Oh interesting!! Will it also tell me where a command is coming from? Like if it's coming from HomeAssistant via an API or directly from within the ISY?
  9. Hi guys, I have a bizarre issue. The guest in my home was reporting that some lights keep turning on every night around 9pm. I finally checked the logs and surely enough there are 4-6 lights that seem to be turning on ever night: My setup is like this: ISY994 --> HomeAssistant (Via official ISY plugin) -> HomeKit (via HomeAssistant Plugin) I don't have ANY automations set on either my ISY994, in my HomeAssistant, or in my HomeKit that would turn on this random collection of lights. This also started happening recently (I'm still going down the log to find out exactly when). Is there any way I can figure out WHO is issuing these commands? Is it the ISY directly? Is it my HA, or HomeKit? It just says "system" in the ISY log. Any help would be greatly appreciated. It's driving me absolutely nuts!
  10. Holy shit. This really sucks. Those 6/8 button keypads are amazing and my entire home is build around them. Damn.
  11. Hey, @MrBilldo you happen to have any thoughts on this one? Would be awesome if there's a way to get the ISY scenes to turn OFF on HA as soon as the states don't match the lights on the ISY anymore.
  12. I would like to do that too but my problem with that is that HA reports the scene as “on” even if not all the lights of the scene are on OR if they aren’t set to the right brightness. So it’s impossible to toggle it even if just a few lights of the scene are on. Do you know a workaround to this @MrBill?
  13. Thanks, mate. I finally took the plunge! Everything seems to work BUT any HA scenes with more than 3-5 Insteon devices and execution seems to become very slow and unreliable. Way slower and unreliable than it was through my homebridge setup. What is your experience with this @MrBill?
  14. About to take the plunge on this and wondering if any of you have any insights on this?
  15. I think I just solved the issue simply by pressing "save changes" in the programs tab, even though, I have made no changes. Now everything seems to work again...
  16. Hi guys, I finally upgraded my ISY994 from 4.5.4 to 5.0.16C and overall everything still seems to work. I can control all of my Insteon devices right from the admin console. However, my programs that used to keep my Insteon Keypad button status in sync with the device status don't seem to work anymore. Previously I had it set up that if I turn on an Insteon light remotely the physical Insteon keypad button would also turn on. That way the buttons and lights were always in sync no matter if the light was turned on via the physical button or remotely. This is how one of the programs for the "Art Light" looks: And here you can see the device tree: I'm not sure why this simple program no longer executes after upgrading to version 5. Is this no longer the recommended way to keep an Insteon Button Light status in sync with the device? Any help would be greatly appreciated!
  17. Hi guys, I have an ISY994i and the following types of Insteon devices: Dimmer Switches Dimmer Keypads On/Off Keypads Dimmer DIN modules On/ Off DIN Modules Open/Close Micro Modules (for shutters) On/Off Outlets I would like bring all of those devices into HomeKit via Home Assistant: ISY -> HA: Universal Devices ISY994 - Home Assistant HA -> HomeKit: HomeKit - Home Assistant My goal is to expose all of my Insteon Devices to Home Assistant and the bring a selected group into HomeKit. I’m wondering if anyone is using this setup as I have a few questions: has this been a stable setup in your experience? I’m looking for a rock solid solution that works. Will I still be able to have dimming control over my dimmable devices from within HomeKit or will they all just become on/off? I saw this on the home assistant plugin site: “All Insteon scenes configured in the ISY994 will show up as a switch in Home Assistant, as they do not support dimming or setting specific brightness settings as Home Assisstant’s light component.” Is this only scene specific? Can I still dim my dimmer switches? Will this solution support the open/close micro module and expose it as a window covering in HomeKit? Is it possible to expose a single button from the keypad switch so that I can use it as an automation trigger inside of HomeKit? For example: the user presses button D on the Insteon keypad and I have they trigger the “Good Morning” scene inside HomeKit. I would only want to expose maybe 1 or 2 buttons from my keypads into HomeKit. I’m currently using Homebridge and this plugin to bridge my Insteon devices into HomeKit but it has some shortcomings: no longer under active development Doesn’t support ISY 5 Doesn’t support open/off micro module Starting to fall apart a bit So I’m looking for a new solution and was hoping that maybe the Home Assistant route may be the answer. Looking forward to hear your thoughts!
  18. Hi guys, I have an Insteon DIN on/off module connected to a towel heater in my bathroom. I set up a scene on my ISY so that I can turn the module on and off from one of my Insteon Keypad buttons. I am wondering if there is any way on the ISY to start a 30 minute timer whenever the module turns on and then turn it off after 30 minutes. So as soon as the device is turned on the timer starts and turns it back off after the timer expires. That way if someone accidentally forgets to turn off the towel heater for several hours it won't burn down the house. Is there any way to implement this with an ISY program? Any help would be much appreciated.
