HughS
  1. Both lights are on on the ISY network jack, but they are both solidly lit. This problem started before I replaced my modem/router. I thought it would resolved when I installed the new modem/router. When I launch the Ud Admin Panel on my PC it doesn't access the ISY. The word "File" is the only item in the menu at the top of the page. When I open that menu "Logon" is greyed out. I thought you could access the ISY via direct cable connection through the micro USB port but I tried that and either I don't understand how to do it or it doesn't work with my device.
  2. I've swapped out the Ethernet cables to to router and the PLM without any change so the only thing left is to PLM itself. It isn't showing an error via the status light but I've reset it and still no change. I guess the next thing is to replace it.
  3. The door and memory lights are flashing on my ISY 994i and I can't connect to it via the network. I have replaced the ISY994i but the new unit did the same thing as soon as I plugged it in. I had a problem with the modem provided by my internet provider so we have replaced that, but the lights are still flashing on my ISY. Does anyone have any suggestions?
