kimbray
Everything posted by kimbray
  1. The blinds I have are Alta automation motors running at 463Mhz and not zWave. Do not think this will work.
  2. OK, I ahve AMazon Alexas but wondering if I can do via Google Home. https://shadeomatic.com/wp-content/uploads/2021/02/BLISS_QSGuide_GoogleHome.pdf I CAN connect and see my BLiss Automation blinds in Goggle Home (did via above). So now is there a way to have a sensor for light in ISY based on Lumen variable OPEN and CLOSE the blinds via the ISY portal WITHOUT spoken words? If yes, how do I do? Also one other thing, my ISY port access/email is not a gmail account so when trying to move over spoken words from port to Goggle Home, it does not work (don't think I need but wanted to share as well). Thanks!
  3. I tried following direction via this. Got the ISP portal set up with a contact variable and discovered in Alexa. However when I try to go when this happens do this and I select smart home and the contact sensor I created (it is there and was discovered), it says device is not currently supported. Any other ideas?
  4. Yea, here is the problem, I cannot find the IFTTT module/applet for Alta Blinds. When I click the link in the Bliss app for IOT and ITFFF it gives me a not found in IFTTT. That is why I believe I have to use Alexa. Could be wrong so maybe more back and forth in this forum. Thanks all!
  5. All I have an ISY 994i. I have a non zWave blind motors (Alta Bliss). I have Aeotec luminance sensors. I want to be able to use UD Admin console to raise and lower blinds via If/then/else statements. To do this I have to use the portal capabilities to create actions via Alexa or Goggle or IFTTT hooks. Alta says it supports Alexa (there is a Bliss automation module that I have in my Alexa app). It says it also supports IFTTT, but I cannot figure out how to get that working (on mobile device I have Bliss app and IFTTT, but when I try to LINK it says Could not open requested page. Therefore my only choice is to use Alexa but not sure if this works. I want to use UD admin console, create an IF statement when my luminance sensor gets to a certain level (I can do this easily) THEN, I want to have console kick off an alexa command (not spoken) to open/close blinds. This is the place I am not sure of. Any help would be great and hopefully I can do. Thank you.
