procat
Everything posted by procat
  1. I have two BE469NX-CEN which are having communication problems for me, see attached error message screenshot. The only time I appear to have access to them is right after I manually go to the lock and do something to it, otherwise ISY994i can't communicate with the two devices. I suspect it's a setting somewhere, likely in the lock. Anyone overcome this problem? Much thanks.
  2. Thank you all for responses. The "Fast On"/"Fast Off" commands got me where I needed to go. I have ran into a second issue: Setting the key pad button (E) to On or Off.... It appears all that one can set is the on and backlight levels for the device? See screen shot.
  3. New to ISY-994i IR/PRO, was using HouseLinc So I have three rooms with speakers in ceilings, with three separate amps in the attic. Each room has keypads, one toggle button for on/off, one press button to Volume Up, and one press button to Volume Down. Commands are sent to an iTach (IP2IR) to control the amps. With HouseLinc I was able to capture double tap On's and double tap Off's ... which would turn all three amps on or off as to turn on music in the whole house, rather than just the room you happen to be in and update the buttons in other rooms to reflect the state. I've learned that even though I purchased a IR/PRO, I still have to purchase the network module to control IR iTach's in my case. I still can't figure out how to capture double-tapped commands from insteon devices. Any ideas?
