lip
Everything posted by lip
  1. lip replied to lip's topic in ISY994
    Thanks so much. I did what you said but didn't find any misbehaving ones. I'm wondering if the issue is related to one of my wireless insteon devices like larryllix suggested? One of the issues I have is that the damn isy works so well I don't touch it for a year and forget how everything works...ughhh....
  2. lip replied to lip's topic in ISY994
    Hi, Thanks so much. Actually I am using an insteon hidden door sensors and a motion sensor. I do seem to go through batteries with the insteon hidden door sensor. Is this related to the ISY trying to update the device? I logged in tonight to check a program that seemed not to be working but I didn't have the constant updating tonight.
  3. lip posted a topic in ISY994
    Hi, I constantly have a system busy message with my isy. I'm guessing it might be a program or something from what I've read. What should I be looking for to troubleshoot this? Thanks.
  4. Hi, I suspect my ISY has been damaged by a lightening storm. The insteon PLM connected to it was damaged and the ISY now has a blinking blue and red LEDs(error and memory). The ethernet port on the back has no lights. Any thoughts on what I should do? Do I need to buy a new one? Does UD repair them? Thanks.
  5. Thanks
  6. Thanks Do you have the HD or orchestrated? What does ekeypad give you?
  7. Thanks Which version do you have?
  8. Thanks Will do
  9. Thanks Does mobilync pro or orchestrated have the ELK plug ins? The portal comes with the Amazon alexa integration I believe Thanks
  10. I've had the ISY and an ELK for a couple of years. I have the ELK plug in for the ISY I want to be able to integrate alexa with the isy and Elk and have a mobile app. Would I need to get the portal and integrate it with mobilync? What options do I need from isy and mobilync? I have an iPhone Thanks
  11. lip replied to lip's topic in ISY994
    Hi, Thanks Teken. I'm always impressed to see you helping everyone out...don't know where you get the energy! Ok. So last night I went around and cleared the impending writes so the water symbol appeared. Unfortunately still no heartbeats were present I woke up this morning and checked the AC to see that there were no longer even ON or OFFs on the DRY and WET sections. The heartbeats were also missing. I have updated my Java app, cleared it's cache. The UI and firmware of the ISY match and are both 4.6.2 How do I hard reset the devices? I found the restore option under the device in the AC but not hard reset. So I seem to be moving backwards. It's very strange as when I first installed these with the ISY I had no issues and no issues with the great program that the fellow member wrote. Thanks in advance.
  12. lip replied to lip's topic in ISY994
    How should the heartbeat work? I had thought it should come on after pressing the button but it doesn't. Thanks.
  13. lip replied to lip's topic in ISY994
    Answered my own question. Thanks Teken!
  14. lip replied to lip's topic in ISY994
    Thanks Teken I feel like an idiot but is that done by pressing the button continuously until it flashes?
  15. lip posted a topic in ISY994
    Hi, Im using that awesome program from one of the users on this forum for the leak sensors with my ISY. Things were going fine and then earlier in the year I had some issues with my ISY and lost the program and had to re-write them all which I just got around to do. One of the sensors heartbeat is never working and I'm getting the error. Questions: 1. The heartbeats do not come on straight away when I press the button, is this normal? Usually the next day they are present 2. Have a look at the image. Why do some of the leak sensors have a water graphic and others have 101? 3. The one devices heartbeat hasn't worked at all yet it catches a leak when I test it. The battery is 1.7V and it's close to an access point. Any ideas? thanks in advance, LIP
  16. Hi Thanks guys. Yes, this was the problem. I had to also reset my M1 ethernet adapter as it received the same subnet from the last router. This was a pain... The z-wave schlage locks also decided to lose their connection to the ISY. All is sorted though. ​Thanks for your quick responses. If anyone wants to know how I did it, shoot me a message and I'll be glad to walk through the ISY and ELK instructions.
  17. my Elk info seems to be all missing...perhaps I'm forgetting something...shouldn't the backup had the information?
  18. I ended up doing the reset and it all worked ok. Easier than trying to play around with the network. Thanks!
  19. Thanks for the reply. The link took me to resetting the ISY...is this the only solution? ​ ​Thanks.
  20. Hi, I recently changed my router and the new one has a prefix of 192.168.1 whereas the old one I believe had 192.168.0 I can no longer find my isy on my network with the java tool. My router sees the device as 192.168.0.210 but when I try to add this to the isy java menu, it can't find it nonetheless. I have searched on the forums and found someone talk about a similar issue which they solved by using the CT command but I cannot telnet in to it as it says "Connecting To 192.168.0.210...Could not open connection to the host, on port 23: Connect failed" Any ideas? I don't want to reset it if I don't have to. Thanks in advance.
