Ecobee setup
II it possible to setup Ecobee in UDI if I don't have any Apple devices. I have setup Homekit node but I am still confused. I need one of those for Dummies manuals really bad!
Device Properties / Commands
Sent in a ticket! No response?
Yes I am on the latest firmware.
I have synced several times. Not solving problem.
Device Properties / Commands are not reading correctly on Mobile App. Some examples: DON FOR ON DOF FOR OFF FDUP FOR FADE UP FDDOWN FOR FADE DOWM ETC. ETC
New Release 1.5.13
Receiving this error: --when I sync with UD Mobile I do get errors: yolink 1.6.2 0. Notify Node Server Dev!!! Status name is missing for : ST. Node Server Instance: 6 Anything to worry about. Everything seems to work fine??
config file retrieve from polisy
thank you worked
Need command line to retrieve cong.txt from polisy. TY
Release 5.9.1 discussion
That explains it . TY
Definitely not like yours. I'm using Polisy with a 700 stick.
Don't see anything that says backup under the Zwav menu????
Does z-wav get backed up in Polisy after Iox backup.
Tile size wrong on ud mobile
Me to !
New Release v4.0.8 - ESPHome version
Actually, it was not a big problem adding key and value. Once the problem was identified it was a very easy fix. Could the problem be remnants from the previous MQTT installation. I did try two ratgdos, thinking one was bad, installed in two different slots. neither did the trick. Things are working very well. Thank You
Did this: Key: gdodevice Value: <ip address of ratgdo>;<Name of ratgdo modified as per the release notes> All works!!
