ExDvtch
Everything posted by ExDvtch
  1. Thank you for the help!
  2. The only blue light on my device is the blue power button on the front. Edit: I do have a blue LED on the back but it's not lit up. Possibly then I need to upgrade my board? I believe I upgraded from running 5.0.16C before this. Is that not the right number you're asking about?
  3. Upgraded to 5.3 and now my i no longer see any of my z-wave devices. Upgraded from 5.0.16C where Z-wave was working. My menu just says "Z-Wave dongle not responding"
  4. That does allow me to change the phrase i use to trigger, but then i'm just setting up two commands, "open" and "close" to do the same thing that my current command does ("turn on garage door"). Currently i'm using Switch in the isy portal for the google home category. i'm still lost on how/if I can get google to have unique open/close commands.
  5. Can you share the setup that you used to allow you to say "Open the Garage Door" and "Close the Garage Door"? I'm still stuck saying "Turn On Garage Door" for both open and close because my isy portal is passing it on as a switch. I could set it up with IFTTT i guess and Webhooks but then i wouldn't retain Status in the home app.
