xyzsal1
  1. I have set the Lat, Long setting in the configuration tab. ISy is set for my timezone. The program executed properly after I clicked the "Run(IF)" . Thank you all for your suggestions on this matter as I'm new to the ISY and finding my way around.
  2. I think I may not have done it correctly as when I hit the "Run(IF)" button it seemed to have executed the IF Then , ELse statements correctly.
  3. I am trying to create a flasher to flash my lights at a certain time. I tried using the repeat function and it works okay. The IF statement uses the From To to check the times. If I use a defined time, it works fine but if use the Sunrise time, if does not flash my lights. Any ideas?
  4. Ok I will try that. I was under the impression that all RF devices like Remotes and Motion Sensors, had to be added manually?
  5. I have an Insteon Mini Remote 2342-2. The device address is worn off the back making it barely readable. I am wanting to link the remote to my ISY but don't know how to add it without being able to read the device address. Any Ideas?
