clutch2sft
  1. I have three modules; two 2477D and one 2477S, call them 2477D-A, 2477D-B, and 2477S-A I have 2477D-A and 2477S-A in a scene (Scene A) as controllers with 2477S-A on level @100% and 2477D-A on level @0% I have 2477D-A in another scene (Scene as a responder and 2477D-B as a controller Scene B works as I expected it to Scene A should turn on whenever 2477D-A or 2477S-A are tapped on but the load on 2477D-A should remain off - this does not work as I thought it should. If you tap 2477D-A on then both the load on 2477D-A and 2477S-A are energized. If you tap 2477D-A on side again then its load turns off and 2477S-A load remains on. Odd behavior to say the least in my simple head. So to the question - is it possible for a 2477D load to stay off when it is tapped on - or to say another way can it provide control only without turning on?
