ahbrown41
  1. I actually have the insteon floodlight with the "sense" sensor so no access point is necessary. I have pulled the plm a few times and reset all the insteon devices with the isy-99i. No good yet..
  2. Hello all, I have an ISY-99i that I have had setup for awhile. I have my garage door motion sensor trigger a bunch of lights in the house and on he way to the house. This program worked great until a week or two ago. Now, it does not work at all as programmed. I have the garage light "Control" event (Also tried status) turn on the other lights. From the ISY-99i I can turn the garage light on and off easily. If I have the status trigger on, this then triggers the other lights. However, if I trigger the light by movin in front of it, it appears to no longer send a message the ISY-99i can receive. If I clear the log and then look at it after triggering the light, I see no entries.. Is it possible it is the second phase, and whatever allowed it to magically work before (I have no bridge) has now stopped working? Any ideas would be welcome, this was the primary reason for my investment and I would love to have this working again..
  3. Thanks for the reply. I tried making light 1 a controller and light 2 a responder but it is still not doing what I am looking for (Light 2 just ramps up to high). How responders work is not 100% clear to me in relation to a straight program, is there a good FAQ somewhere? What I am looking to do is dim and brighten the lights together at the same time. So if I brighten one, the other should brighten to the same level and stop (I tried fade stop). I want to have the lights do the same for Light 2 as well in relation to light 1. Can I do this? Thanks!
  4. Hello all, This should be really simple but for some reason it is not working for me. Here is the code to brighten the light: if Control 'Light 1' is switched bright then Set 'Light 2' bright When I do this, if I open the event viewer, I can see things happening but 'Light 2' is not getting brighter.. Amy I missing something?
