listen2this1
Everything posted by listen2this1
  1. Son changed rooms in the house. I renamed the devices that are not in his room. I deleted the device in the Alexa app (bad move) and now the ISY Portal states its already used. It does not show up on the list, only when I use the drop down. How do I remove from the drop down if its not on the list? Lesson learned is to just move the switches. ugh.
  2. Update, I have them working after many tries. I will place the remote in set mode and then update. Will accept scene most of the time.
  3. I have attempted that. This is the scene for Button A. When I push the button, the lights will go to 100%.
  4. Scenario: In the process of adding sliding doors to isolate my media room. I would like to keep the existing switch location, outside the room with 2477d, and control them with a Mini Remote. This would allow me to start the playing the music/movie and then control the lights. The goal is to have Button A be a scene and Button B be another and so on. I can get them to turn all on and all off but not at a specific dimming percentage. I just can't find the correct options to make this work correctly. Any suggestions? TIA
  5. I will give this a shot, Thanks
  6. Garage Motion Lights On - [ID 000D][Parent 0001][Not Enabled] If 'Motion Sensors / Motion (Garage)' Status is On Then Set 'Garage Lights' On Set 'Living Room Lamp' On Else Wait 1 minute Set 'Garage Lights' Off Set 'Living Room Lamp' Off The one minute would be 15. At 1 minute for testing.
  7. I have read that. You would think someone would release the data.I will try a higher number and see what happens.
  8. Have a MS2 that is located in my garage. I have a program that states if no motion after 15 minutes then turn off lights. It runs great if I have it set to 1 minute. The issue is the sensor sends false positives enough the lights might never shut off. If they do it might be 5-10 minutes before they turn on the light. Motion Setting in Image.
  9. Not sure how, the ISY communication is instant. Think having it and the PLM on the same outlet is bad?
  10. Set switch to off in the app and it takes 15 seconds to respond, if it works at all.
  11. I just want a better hub from them. If they are going to make a fancy app they better have a hub that responds to commands.
  12. I have the chance to purchase many Legrand Radiant WiFi switches for cheap. The question is being WiFi can I get them to work with the ISY? I have experimented with using a Polyglot and Sonoff switches but not having much luck. Is the only way to make these work is with the Polyglot? Link: https://www.legrand.us/radiant/products/smart-lighting/wwrl10wh.aspx Thanks for any help.
  13. I am tired of shutting off the lights and having to use my phone to see down the hall. I have a table remote that accomplishes it for me but I am wanting to tell Alexa to turn off everything and she does so after a set delay, maybe 15 seconds. I have tried with creating a program. If I run the program via the console it works great. If I continue with the portal she won't respond to the commands. She states she can't find the device. Any suggestions?
  14. Ok, I am really confused but its fixed. At some point my motion sensor that was set to start monitoring at 10:00, I thought was 11, was changed to send the entry message when monitoring is started. I haven't been in that program for at least a year. Thanks for the help.
  15. I think we are not quite on the same page. I had the program working great when enabled. This program is the only one that uses James_Front_Entry_Text. I have been using it occasionally because I am having a struggle with getting a KPL to work the way I want. I am enabling it tonight to see if I get the alert at 10pm. If it continues I will remove like Techman suggested. Again thanks for all the assistance.
  16. This is the only things that happened around that time.
  17. James_Front_Entry_Text - [ID 0009][Parent 0001][Not Enabled] If Status 'Front Door.2 - Door Closed' is Off Then Send Notification to 'James Text' content 'Front Door Open' Else - No Actions - (To add one, press 'Action')
  18. Not sure what program is doing it. The only program that has the sensor in it has been disabled. I will post screen shot of it tonight.
  19. I am not using the contact indication reverse feature. There isn't anything that is to run at 10pm. The one that baffles me is the log file shows nothing. I think I will remove the sensor and see if it happens tonight.
  20. On average of 4 times a week I get an alert that my front door (Open/Close Sensor) has opened. It happens exactly 10:01pm but the log doesn't show anything at that time. There's no active alerts on that sensor. Has anyone else had such an issue?
