asperber
  1. What about if i only have firmware 5.0.16? Should i upgrade to 5.3?
  2. Turns out I have version 4.55. Is it worth it/possible to upgrade the dongle to zwave 500?
  3. I have, and tried resetting zwave from the ISY admin console. How do i check the zwave version firmware? It's internal, how do i add an external zwave antenna to my isy994?
  4. My ISY isn't seeing any zwave devices or letting me add them to my controller anymore...Any suggestions on how to fix this?
  5. I did that numerous times, no luck. I tried on a PC as well to use the admin console. What seemed to work (so far) is I had a backup of the ISY, I did a factory reset and restored it with that backup.
  6. Also, now i cannot access my ISY from my mobile app.
  7. Hi, I have been having no problems with my ISY, and suddenly it started giving me a socket error. I tried restarting the ISY and cannot get it to function...
  8. I have an Inovelli switch I'm trying to add to my ISY but everytime I add it it gives me an error "the zwave network failed to securely include your new device". I have tried factory resets on the switch and excluding it, but can't get it to pair. Any suggestions?
  9. bump
  10. I have been using an insteon smoke bridge with my first alert smoke detectors. I got it to work when I pressed test, and it shows TEST as ON in the isy software. The only way to get that to turn off is to manually click query. Am I doing something wrong?? Shouldn't it auto query?
