Cooper0705
Everything posted by Cooper0705
  1. Interesting, makes sense. I'll work on figuring out how to fix that tomorrow. I suppose the easy fix would be to turn off the light when the door is closed rather than waiting 10 min. Usually the door is open until I walk inside and close it. Can you explain how to turn on the scene to light the KPL? I added it to the program and nothing changed. The scene has 2 switches and 3 KPMs. One KPM is the controller, the rest are responders. Garage Door Open, Lights ON - [iD 0007][Parent 0001] If From Sunset To Sunrise (next day) And Status 'Garage - Mud Rm / Garage Door Sensor' is On And Status 'Garage - Mud Rm / Garage Lights Mud Rm' is Off Then Set 'Garage - Mud Rm / Garage Lights Garage Door' On Set Scene 'Z Scenes / Garage / Garage Lights Sync 1' On Wait 10 minutes and 10 seconds Set 'Garage - Mud Rm / Garage Lights Garage Door' Off Else - No Actions - (To add one, press 'Action')
  2. Thanks all... It does appear to be working fairly well now, though I'm not sure why. I had the From Sunset to Sunrise (same day) set to test during the day while i was working on it. Here's another question for you experts... When the program runs, 2 additional issues have surfaced. While it does turn the garage light on and then off if I set the wait for 10 seconds, it doesn't seem to turn the garage light off if I set it for 10 minutes. Almost like something is going to sleep and not allowing the program to finish. The garage lights are on but none of the keypads I have controlling the lights show the garage lights are on. the keypads are linked to the light switches in scenes, and they light up if I manually turn the garage lights on, but they do not show the status of the light if it is turned on via the program. Garage Door Open, Lights ON - [iD 0007][Parent 0001] If From Sunset To Sunrise (next day) And Status 'Garage - Mud Rm / Garage Door Sensor' is On And Status 'Garage - Mud Rm / Garage Lights Mud Rm' is Off Then Set 'Garage - Mud Rm / Garage Lights Garage Door' On Wait 10 minutes and 10 seconds Set 'Garage - Mud Rm / Garage Lights Garage Door' Off Else - No Actions - (To add one, press 'Action')
  3. I tried searching the forums but haven't been able to find an answer. I have the Insteon garage door kit an it's working fairly well except i can't figure out how to have a light turn on when the garage door is opened when using the garage door remote (not Insteon remote or device). I thought it would be as simple as creating a program that turns on a light when the sensor changes from door closed to door open. But that isn't the case and any help would be appreciated. Program is attached.
