Wildstar
  1. The PLM is a brand new 2413S rev 2.3. The PLM has 63 links (did a restore) and the ISY still does not report the status. I can control just fine, but I can't see any user changes at the switch level.
  2. Wildstar replied to Wildstar's topic in ISY994
    ​Yes, hundreds of devices and have hit the limit of scenes, and then when adding devices to a scene it takes a long time for all of the updates. Prefer an All Off if there is a way to do it.
  3. Wildstar posted a topic in ISY994
    Is there a way to turn off ALL insteon switches without putting them into a Scene? I noticed if I go to "Network" in the ISY Admin Control Panel I can do this at the bottom. I also can do this from the MobiLinc App, but I have not found the command within the programming section of the ISY (I can only select devices or scenes). I also remember a plug in insteon control device that had an 'all off' command. Thanks for any help here if there is a simple answer...
  4. ​I am trying to do a simple program - when I turn on a fan, I want a program to turn it off 10 minutes later. ​I have tried using both STATUS and the CONTROL in the IF statement, and neither are triggering when I change the switch state. ​This said - when I manually hit the switch, the state does not change on the ISY Admin Control Panel - however, I can control the switch from the ISY Admin Control Panel. ​I noticed, none of my manual changes at the switch locations are changing the state of the ISY Admin Control Panel. ​I am assuming if I can get the status commands from the switches to either be sent, or recognized by the ISY Admin Control Panel, then the program will run. ​Any ideas on how to do this are appreciated! Thanks
