Help with an IF/THEN
Hi again,
I am sorry for asking 1000 questions, but getting down to the really nitty gritty programing for the ISY is hard for me... So I thank everyone in advance for your help and patience!
I have a button on a KPL called "Bedtime". When I press this, all the devices on the first floor go off... lamps, fans, ceiling lights etc... However, I want to be able to press it and have all the 2nd floor devices go off, but also turn on devices on the third floor so when we get up there, it isn't dark... for example, the bedroom light, stairs, hallways etc.
I would assume I have to do this with programs and scenes, but I am having a lot of difficulty figuring it out.
Any help would be appreciated!
Without trying to define your requirements for you, or to assume your needs are more nuanced than indicated, I offer the following concepts as ideas from which you can elaborate and ponder further. Specific details would depend on what scenes you have already, and which devices you want to go off
configure your KPL button as "non-toggle off"
create a program such as:
if
control KPL button is turned off
then
turn off all applicable scenes
turn off any other devices that were not included in the scenes
turn on any applicable scenes
turn on additional device that were not included in the scenes
else
nothing
Are you currently doing this with scenes only, or are programs involved?
This is what I would start with;
Create three Scenes, say 1st Floor, 2nd Floor, 3rd Floor. You can name them anything you wish, I'll just use them as an example. Place all the devices you wish to control as responders in the three Scenes.
Then create a Bedtime program;
Control 'Bedtime' is switched On (this is your KPL button)
Set Scene '1st Floor' Off
Wait 10 seconds
Set Scene '2nd Floor' Off
Wait 10 seconds
Set Scene '3rd Floor' On
The Wait time may be shorter or longer depending on how many devices are in each Scene.
~Mike
