3-Way Switching and Grouping
Hi,
I finally set up 3-way switching and I grouped them as per instruction, and it works only on local. If I turn it on or off from ISY, the other switch doesn't respond. I just bought this 3 months ago and everything is new to me, I spent all day to figure it out the 3-way switching. :)
That is the way Insteon works. To control both switches together turn the Scene On/Off. When an individual switch is controlled that switch does not control its linked responders. This allows Insteon to control an individual switch without affecting any linked devices.
Yes, that is what I did.
Thank you!
