best way to do this? outside event code
on the quest for ir nirvana, I'm working on a couple of programs that will watch for certain ir events that get set via the rest interface though the lirc program running on the Pi.
If I hit the pause button 3 times in 5 seconds turn on a light
if I hit play button 3 times in 5 seconds set a scene Movie on
if I hit tivo tivo, make sure the tv is on (discrete on command), turn on the stereo, wait a few seconds and change the input to tivo
Currently I think I need 9 total programs just to monitor this stuff and react. Example of pause programs
Program 1 looks for a state variable to be greater than 0, this being set via the rest interface from the irexec program on the pi
       $sTivo_play_counter_ir > 0
       $sTivo_play_ir += 1
       $sTivo_play_counter_ir  = 0
       $sTivo_any_ir  = 1
each time the play button is pressed the $sTivo_play_ir gets incremented, which
starts its 5 second countdown.  This watches for the control variable to increase
which means play was hit.
We also tell the system the basement is occupied
the wait program that resets the $sTivo_play_ir to 0 within a few seconds of the last hit of the button
       $sTivo_play_ir > 0
       Wait  6 seconds
       $sTivo_play_ir  = 0
When the Tivo Play button is pressed, start timer to reset it to 0 within 6 seconds.
and finally the program that does the work
       $sTivo_play_ir is 3
       Set Scene 'Movie_Basement' On
       $sTivo_play_ir  = 0
if tivo play is hit 3 times in 5 seconds, turn off some lights
