How to hide a device/scene
Is there a way to hide a device/scene from ISY and third party apps? I added some switches/scenes to ISY to program them, but now that they are programmed I don't need them in ISY anymore (they are slave and dummy switches or scenes I would never activate directly). I would create the scene manually outside ISY, but it is too complicated. I just want to take them out of ISY but still keep the programming. 'Remove device' took the programming off the switches. Thank you!
Pull the air gap switch and/or unplug device(s) before Deleting from the ISY.
To be sure I understand, these devices will not be referenced by any device(s) that remains defined to the ISY? You are not trying to create what will look like broken/half links to the ISY?
Hi LeeG. You are correct. These switches and scenes will not be referenced by anything else in ISY. Thank you for the information. Makes sense now! :-D
Sent from my Galaxy Nexus using Tapatalk 2
