Help with ISY and Fade
im looking for a way to fade the lights to 10% right now i just jumps to 10% and thats not easy on the eyes. so how do i fade to 10%
but it does not work run a run a program ones the program runs it jumps to the 10% i want to do this with in a program
The Insteon Direct command does not have a placeholder for Ramp Rate. Use an Adjust Scene where both the In Scene and Set parameters specify the device. The device must be a Controller in a Scene for it to appear as a selection in the In Scene parameter. After the Adjust Scene statement is executed the issue the Insteon Direct command. Note that some older devices require a power cycle for a change to the Local Ramp Rate (or Local On Level) to take affect. This solution also affects what happens when the local paddle is pressed.
If the Program action should not have an effect on the local paddle press, define an ISY Scene with the device as a Responder with the Responder On Level and Responder Ramp Rate as desired. Then have the Program turn the ISY Scene On. No device power cycle is needed for this solution.
