Program to flash lights x number of times
I had a program (I copied off this forum) to flash certain lights when my garage door was opened during the night. I had to delete the program and forgot how to program lights to flash using the "repeat" command. Can someone give me an example? Thank you.
This Program assumes the I/O Linc Sensor turns On when the door is opened. Might have to change the If On to If Off when I/O Linc works the other way.
       From    11:00:00PM
       To       6:00:00AM (next day)
   And Control 'IOLinc-Sensor' is switched On
       Repeat 10 times
          Set Scene 'Scene KPL Button A' On
          Wait  1 second
          Set Scene 'Scene KPL Button A' Off
EDIT: added the time range. Was not sure what aspect of the Program was an unknown
