Adjusting On Level of Switchlinc Dimmer based on time
Hi,
I recently upgraded from a Smartlinc to and ISY 994i, and was trying to play with the program options. What I would like to know is, is there a way to set the on level of a switchlinc (not a scene), based on the time? I can figure out how to change the scene on level based on the time, but I cannot seem to figure out how to use a program to change it so that when I turn on the switch locally, that the on level reduces late at night.
Thank You
Charles
The SwitchLinc must be a Controller of a Scene. It can be a dummy Scene that is not used. Use the Adjust Scene Action statement, the In Scene and Set parameters specify the node name of the SwitchLinc. Again, to be able use the SwitchLinc node name in the In Scene parameter the SwitchLinc must be a Controller of a Scene. Specifying the SwitchLinc node name in both the In Scene and Set parameters causes the ISY to set the Local settings. These are the settings which affect what happens when the paddle is pressed..
