Just got ISY9941/PLM - question
Hi,
I just received my ISY994i/PLM in the mail along with 2 access points and 2 dimmer controls and a motion control.
My question is after I install the ISY/PLM should the next step be to install the access points? I would think so since the location for the dimmer switches is on a different floor than the ISY/PLM.
Any other suggestions for the new install?
John
Installing the Access Points is a good idea. Use the built in communications test to verify communications with each other and on opposite phases of the home.
Access points are not installed into My Lighting as a module.
