New Router - Can't reach old static IP (wrong subnet)
OK, I know this is probably a simple issue, but my searches haven't turned up anything and my brain is not firing on all cylinders after the 5 hour ISP install today (lots of new wiring, so I'm pretty appreciative of AT&T for the free 8 port switch and running of all the new ethernet).
Anyway, old subnet was 192.168.0.* and I had the ISY set to a static IP. New subnet is 192.168.1.* and I can't access the ISY through a browser anymore. How do I log in and change the static IP to match the new subnet?
PJ
On your machine, go into your nic properties, and add a second IP address on the old 192.168.0.x subnet. You'll then be able to access it. (Assuming you are running windows that is).
Once changed, remove the secondary address from your machine.
