garage door issues
i have been trying to get a master 'arm-house' program, problem is with the garagedoor sensor ...
for some reason it keeps flipping the variable while the door is closing ..
for close status;
if controle garage-door-sensor is switched on
then $garagedoor status is 0
and reversed for open;
if controle garage-door-sensor is switched off
then $garagedoor status is 1
then to close the door (only if it's open) i use
then set garagedoor open-close on (the relay)
for 'master control is use
if $armhouse is 1
then run program close-garage
and if i flip the amrhouse var from 0 (house unarmed) to 1 (armed) it works fine .. but randomly the garage sensor kicks in and stops the door halfway etc.
am i going about this the wrong way ?
This logic is not correct. The If Control xxxx is switched On is looking at the On command coming from the I/O Linc Sensor which occurs when the door is physically moving, either to closed position or opening depending on the type of magnetic switch used and whether Trigger Reverse is used. The Action taken is to turn On the I/O Linc Relay which initiates door movement again.
If Sensor On is door opening then turning the Relay On will stop the door movement as part of the door safety system. Same thing happens if the manual door switch is pressed to initiate door movement and the manual door switch is tapped again. The door stops.
I am with LeeG on this one...something is not quite right.
I cannot help but suspect I am missing part of the puzzle here. How do you inend to actuate the doors when at home or arriving/leaving? Existing button? Insteon keypad or switch? Phone app? What purpose does the "garage door open/close" variable serve? Are these state or integer variables?
Assuming that I correctly understand what you are trying to do, perhaps the better approach would be:
a) ensure that the garage door status variable is an INTEGER variable. (Integer variables do not trigger program evaluation.)
B) update your close program:
if
status $garagedoor = 1
then
i am using the phone to flip the 'armhouse' var (for now) using mobilinc, i simply change the armhouse from 0 > 1 to initiate the logic.
that starts, (works)
if $armhouse is 1
which has
if garagedoorstatus_int = 0
i moved it to an integer var .. and guess what .. it works now, no more funky behavior while the door is opening/closing.. thanks !!! that's half the battle fixed.
BUT :P
now even despite the state of the integer var, even when the door is closed (0) it still runs the 'then' while it should not
and thus opens the door :( it doesn't seem to care either 0 or 1 it will still run the set garagedoor open-close on.
i do see the garagedoorstatus_int behaving nicely .. its 1 for open, and 0 for close...
thanks guys !
One of the reasons that I asked about your purpose for the variables (I missed your response to this) was out of suspicion that you have other programs in place that may also be triggered by these variables. I also asked about how you intend to open and close the door (I missed this response, as well) wondering whether you have other programs or scenes that could trigger the type of behaviour you describe.
Suspecting that I am having trouble seeing the entire picture here, one thing that has gone unspoken about your program:
if $armhouse is 1
I assume this is a paraphrase of your actual program. In your actual then statement, does your program include something like "(then path)", or "(IF path)"? If so, make sure you run IF path.
Some things you can check to aid in troubleshooting is to watch the value of the variables as the door opens and closes, to make sure that these are tracking correctly. Have you confirmed the variable is 0 when closed and 1 when open?
Otherwise, I don't see anything in the programs you presented which I can identify would result as you describe.
thats it !!! it was starting at 'then' not at 'if' so it always send the on to the relay.... AWESOME
thanks guys ! if there is any easy way to copy paste the statements out of the ISY, i'll post em ...
TX !
#armhouse
$armhouse is 1
Run Program 'lock-doors' (If)
Run Program 'close-garage' (If)
Run Program 'arm-sense-motion' (If)
#lock-doors
Set 'downstairs / door-On' Lock Door
#close-garage
$garagedoorstatus_int is 1
Set 'garage / garagedoor-open-close' On
#arm-sense-motion
Control 'garage / garage-Sensor-Sensor' is switched On
Or Control 'upstairs / upstairs-landing-Sensor-Senso' is switched On
Or Control 'downstairs / frontdoor-sensor' is switched On
Or Control 'outside-front / fence-sensor' is switched On
And $armhouse is 1
Send Notification to 'xxxxxxx' content 'motion detected while house is armed'
#thevariables closed door
Control 'garage / garagedoor-open-close-Sensor' is switched On
$garagedoorstatus_int = 0
#thevariables open door
Control 'garage / garagedoor-open-close-Sensor' is switched Off
$garagedoorstatus_int = 1
Thanks for posting.
I have a couple of thoughts going through my head on your programs, but think you said all is working, so why try to fix something that is not broken.
Post back if you run into anything strange or unexpected.
