Multi-way switch and KeyPadLinc Button for a Scene
Hi,
I have a question regarding the functionality of a button on a 8-way KeyPadLinc switch. I have a scene that contains a hall switch, kitchen switch, eating area switch, and the B button on the KeyPadLinc.
What I want to happen is when the B button is pressed (turned on) the hall & kitchen lights turn off and eating light dims to 35%. I have this working by setting these specific levels when the B button is highlighted in the scene - not at the overall scene level.
When the B button is press again (turned off) - all of the lights turn off - essentially the eating area turns off since the other two are already off. What I WANT to happen, is when the B button is turned off - all of the lights turn on to 100%. Is this possible? Or do I need to program another button on the KeyPadLinc to turn all the lights on?
John
Is this possible?
It is, but not with B button as scene controller. The only way that I know to do this is by a program:
if
status b button is on
then
set lights to low level (best with a scene, possibly)
else
set lights to 100% (perhaps another scene with same devices, higher ON level)
