Insteon 2441TH Thermostat
Can any one verify that the ISY is seeing temperature change messages from the Insteon 2441TH thermostat and properly reporting them as ST state feedback to a subscriber?
I never see a temperature change coming from the ISY to my subscribed application. I see all other messages. I am not sure if it is the ISY or the Thermostat.
All other tings get properly reported and my subscribed application sees them. In addition the Rest interface is properly setting and adjusting the various modes.
At this instant the Thermostat has a displayed temperature of 77, but the ISY994 is showing a temperature in the admin console of 78 and that number never seems to change ergo I suspect I have a bad thermostat
I see temp (status) changes from my 2441TH. I increased the ambient temp several degrees with these temp change messages being the result as the ambient temp returned to normal.
Tue 09/10/2013 11:33:28 AM : [iNST-SRX ] 02 50 1D.6C.D6 22.80.0B 01 6E AC (AC)
Tue 09/10/2013 11:33:28 AM : [std-Direct ] 1D.6C.D6-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Tue 09/10/2013 11:33:29 AM : [ 1D 6C D6 1] ST 172
Tue 09/10/2013 11:33:36 AM : [iNST-SRX ] 02 50 1D.6C.D6 22.80.0B 01 6E A5 (A5)
Tue 09/10/2013 11:33:36 AM : [std-Direct ] 1D.6C.D6-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Tue 09/10/2013 11:33:36 AM : [ 1D 6C D6 1] ST 165
Tue 09/10/2013 11:33:42 AM : [iNST-SRX ] 02 50 1D.6C.D6 22.80.0B 01 6E A2 (A2)
Tue 09/10/2013 11:33:42 AM : [std-Direct ] 1D.6C.D6-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Tue 09/10/2013 11:33:42 AM : [ 1D 6C D6 1] ST 162
Thanks for the reply Lee, Out of curiosity what did you do to get the displays you posted. I assume you were using the admin console.
I used the event viewer in the Admin Console. The Admin Console is a subscriber like any other application. It was easier than trying to catch screen captures of the temp changes displayed for the node.
Lee, I just went to cancel my question as I found the event viewer> It is what I needed.
I think my major problem is with the Insteon Thermostat. It responds very quickly to humidity changes there being a couple every minute, but very slowly to temperature changes. I forced the ambient up to 80 degrees with a hair dryer. It is now taking a very long time to see the ambient down at what the room temperature really is but it is slowly dropping.
