Creating "Activities"
Hi all,
I was hoping to get some help with creating, I guess what I would call an "activity"... meaning, I have a KPL with a button that says "Nighttime". When I am ready to go upstairs for the night, I can press the "Nighttime" button and it will do the following:
-Turn off the lights in the living room, kitchen etc
-Turn on the stairway lights, bedroom lights etc
However, I want the button to ONLY be able to do that, meaning if I press the button, it will only turn OFF the living room lights and only turn ON the stair lights. So if I were to press the button again, it basically wouldn't do anything unless after I had pressed it the first time, I for whatever reason turned the kitchen lights back on.
Does this make sense?
Set the KeypadLinc button to non-toggle On mode.
Add the various devices as Responders to an ISY Scene that has the KeypadLinc button as Controller of the Scene.
Set the devices that should turn Off to a 0% On Level. Set the devices that should turn On to whatever On Level each device should turn On. Both sets of On Levels are defined when the KeypadLinc button node name below the Scene name is selected.
Each time the KPL button is pressed the devices will react to the defined On Levels.
