Garage door status on Keypad
I just installed a new Garage door kit from Smarthome. When the garage door is closed the IOlinc's NC sensor reports ON to the ISY and turns a responding Keypad button on. I want the keypad button to be off when the door is closed and on when the door is open. I tried writing a simple ISY program to do this but was unsuccessful.
Does anyone have an idea how I can do this using the NC magnetic switch.
Assuming the KeypadLinc button is a Secondary button define a ISY Scene with the Secondary KPL button as a Responder. The ISY Program turns the Scene Off when the I/O Linc Sensor is On and turns the Scene On when the Sensor is Off
If Status 'io Linc sensor' is On
Set Scene xxxx Off
Set Scene xxxx On
i tried this and for some reason it did not work but I am new to ISY programming so maybe I has somthing set wrong. I'll try again
Make sure the Admin Console is showing the expected Status in the Current State column for the I/O Linc Sensor.
Make sure the Program does not have a Save pending.
Check the Programs | Summary tab. Is the Program being triggered at all (Last Run Time)?
Select the Program name, select Copy to Clipboard and post Program.
