How would I program this?
I want to set my garage lights to go off after 15 minutes of being on.
How would I program that in the ISY? I just can not get it to work?
The on is a KPL on and off is the off switch on the KPL?
Something like this:
       Status  'GarageLights' is not Off
       Wait  15 minutes
       Set 'GarageLights' Off
I don't believe there's any kind of an Insteon 'flash' command, but you could certain have the ISY flicker the lights a few times to warn that they're going off. Or maybe have a KPL secondary button turn on/off to serve as a warning LED.
But you will have to send individual on/off commands to simulate a flash. I wouldn't do it too much/too often, otherwise you could have excessive powerline traffic interfere with other things going on at the same time.
