ISY994i and Insteon Hub
I have recently bought the ISY994i and trying to set up the system. I already have a working Insteon Hub (2242-232). I have connected both as explained in the instructions. I have also upgraded the firmware to the latest 4.0.5. When I log-in to the Admin module it says it's in Safe Mode and check PLM connections.
Any Help on how to troubleshoot?
I am pretty darn sure the hub is not compatible with the ISY. The hub is an HA controller with a PLM built in. The ISY is an HA controller as well but requires a PLM such as 2413S.
Thanks! I have just ordered a 2413S. Can I add Z Wave devices using ISY 994i and this 2413S setup?
Thanks again!!
Oh, you also need a 5v power supply to power the ISY, but then you probably already have one but thought I would mention it just in case.
Z-Wave is in Alpha stages right now, soon to be Beta stage. Once it is available you can order the module from UDI.
