Motion Sensor in Scene -- On Only jumper
A quick question. I've set my Insteon motion sensor for On-Only using jumper 4 and have reset it several times, including a factory reset. Still, when I add it to a scene with a Switchlinc, it will turn off the light after the countdown timer expires. Is there something about using a sensor in a Scene that does not allow me to use the On-only option? or is the sensor perhaps defective?
My remedy at the moment is to avoid a Scene and instead use a program to turn the light on and off (via Wait statement). Works fine.
Thanks in advance...
Yes, indeed, it was. So now, my question is not only answered, but I've learned how to use the ISY to control those options. Wonderful! Tested and fixed. Thanks so much.
