Updating scenes
Sorry as I'm sure this has been cover elsewhere; but I can't find it.
I have a simple scene with a few dimmers and lamplincs. I added a KPL button B as the controller. Then I went into the scene and tried to change some on levels. However, Pressing B seems to return to the previous on levels.
If I remove and re-add B to the scene, it works. But is this really necessary? Is their some easier way to update the controller?
Click on the Red KPL button node name listed below the Scene name. Set the device levels as desired. In Insteon each Controller has a unique set of Responder values. Clicking the Scene name displays the Responder values when the Scene name (PLM is Controller) is used in a Program or from the Admin Console. Clicking the Red KPL button node name exposes the Responder values for the KPL button when the KPL button is pressed.
