jwshome Posted November 25, 2013 Posted November 25, 2013 I have an Insteon keypad button that is a responder to a scene. I'd like to also make it a controller for that scene. Is there a way to "add" the controller capability? I can't seem to find a way to do that. Instead, I remove the button from the scene, then add it back to the scene and indicate that I would like it to be both a responder and a controller. This works fine, but I assume there must be a way to accomplish this in a single step, rather than in two steps. Thanks in advance for any help ...
LeeG Posted November 25, 2013 Posted November 25, 2013 You have to Remove the node from the Scene and then add it back as a Controller. Insteon allows a node to be a Controller of only 1 Scene so be sure the node is not already a Controller before doing the Remove.
