Control Roku from the ISY
I got it working!
Step one: put your roku in developer mode
press the home button and press the following buttons
[Home] [Home] [Home] [up] [up]
give it a password and reboot
http://blog.roku.com/developer/
Step 2: create a network resource
http -> post -> ip address of roku ->port 8060 =>path /keypress/home
Timeout(ms) 500 and C Escaped
Here are the commands you can use:
Home
Rev
Fwd
Play
Select
Left
Right
Down
Up
Back
InstantReplay
Info
Backspace
Enter
Lit_*
http://sdkdocs.roku.com/display/sdkdoc/ ... trol+Guide
I have a Roku 3 so this process should work on older ones too
Note: that the Roku will not let you give it a static ip address but you can reserve it on your dhcp server or router
  • 4 months later...
Hi,
This is great you figured it out. How do you find it to be? Is a great or so so?
Also, do you know if there's any way to go directly to a given channel?
It works very well. If fact I never use the roku remote since my roku is accessible from all tv's in the house. As far as channels I suppose you can create a program to do it. (Ex. Down twice, right once, enter)
