January 29, 201412 yr Just wondering if anyone has any models to recommend or tips for automating an outdoor electric ignition fire pit? I was thinking something like: http://www.hpcfire.com/outdoor/product/ ... ound-bowl/ hooked up to an INSTEON switchlinc or outdoor on/off module. Thanks!
January 29, 201412 yr A switchlinc could work if wired to an outlet by where the fire pit will be. An outdoor on/off module would work well too. It will be whatever you can do to hide the install for it to look good. Because really, it will be how is this pit going to be installed? where will the closest electrical outlet be in relation to this fire pit?
February 4, 201412 yr Author I spoke with a technical rep at RH Peterson who was very helpful and I believe I can do this with a cheaper non-110V fire pit model that uses a battery powered ignition and remote. I can just hook an IOLinc to trigger it turning on instead of the remote. The model I'll likely try is obce-34-01
