Notify program will not Wait
Ed Sybesma
I have tried to create several programs designed to wait a certain period of time, e.g. five minutes, and then call a second program to check the status (of the garage door) and, if the garage door remains open, to send me a notification that it has been open more than five minutes.
Unfortunately, somehow the notification goes out immediately without any wait time.
The following is one example:
Program 1: Garage Door Opening
garage door sensor [sensor number] is switched off
Wait 5 minutes
Run Program “Garage Door Still Openâ€
No Actions
Program 2: Garage Door Still Open
Status garage door sensor [sensor number] is off
Send Notification [with selected addressee set and message]
No Actions
Immediately upon Program 1 being triggered, the notification is sent with no wait or delay.
Is this a bug in the system or some error in my programming?
Is there a workaround?
Thanks in advance.
Ed
The same condition that is triggering the first Program is triggering the second at the same time. If the second program should run only when called by the first program, mark second program Disabled. That way it cannot be triggered by it's If condition.
EDIT: as a side note the first program If has an invalid statement in what is posted. Right click on a program name, select Copy to Clipboard, paste into forum. A simple mistype can result in the wrong conclusions.
LeeB,
Thanks much. The programming error is obvious now that you pointed out.
And, likewise, thanks for your other comment. I was using shorthand, but you are right--that's not such a good idea.
Here's how it should have read.
Control 'Outdoors / Garage Door / 28.C2.81-Sensor' is switched Off
Again, thanks much.
Ed
      377.2k
