3-Way Circuit
I have an 8-button KPL and a ToggleLinc in this circuit. The ToggleLinc will turn the lights on and off. The KPL will do nothing. I have reset the KPL but I fear I am in over my head.
I have same problem with a 3-way circuit with 2 ToggleLincs, i.e., only one switch will control the lights.
All my other installs have not been 3-way and they are working perfectly.
I am using an ISY 994i/IR.
How confident are you that the switches are wired properly? In three way white cannot be counted on to be a neutral. Does any switche loose power when another is toggled?
If wiring is good, add all switches (for a given fixture) to a scene, all as controllers.
I made the assumption you had power to the KPL since you said that you reset it, which is probably a bad assumption. Does it have power and stay powered on?
Can you clarify if you're asking about wiring problems or ISY configuration?
