Dashboard
I continue to love MobiLinc on iPhone. I have a problem executing a program on the dashboard that's configured to run the "Then" branch when touched. Issue has two parts...
1) the sweet spot to select/execute seems hard to locate and 2) when you do find it the feedback is so faint it is not clear it has run. The prior version had very clear feedback that it had been executed. Can this be accomplished in keeping with iOS 7 look.
Hi Hart2hart,
I'm wondering if you could clarify for me what's happening. All the same indicators are there that the program is running or has run, just in a new layout. When you tap the icon, there is a brief spinning indicator over the icon indicating communication with the ISY. The status changes for however long it takes to run the program and then the last run time date updates. This is actually the same as the old v3 just in a new modern layout. The one difference is that instead of the entire row being active (v3), only the icon is active (v4).
Could you clarify what the feedback issue is?
Wes
You're spot on. V3 flashed entire row and the V4 spinning icon is much smaller and with a quick running program is easy to miss.
